Learn more
Realistic 3d - libraries
Good morning. I am new member in the forum. I am working in archicad the last month to built a project of 3 storey detached house. Where i can find libraries to make more realistic my project. They have suggest me to learn the allplan as its better... Any suggestions? Do i need for more realistic 3d results to put it in a 3d programm as Maxon 4d or else. ? Thanks
3 Replies 3
Go to File/ Load libraries
select the libraries you want and click done!
dmanol
You'll want to download such libraries first if the standard Archicad objects aren't sufficient.
There is a page with links to many sites HERE in ArchicadWiki you might want to check out.
thanks a lot !!!!!
