Guru
Reflecting Editable Parameters: A = C & C = A
Hey all,
Is there a way to reflect values between editable parameters?
Or is there some way to make the base parameters A and B visible in the Custom Settings tab.
I am wanting to be able to edit the height and width of my object using both the object settings dialogue and the default Size Parameter.
It is easy enough to make A = C or C = A, but to make them both happen brings into the issue of execution order(?).
Ling.
1 Solution
What about ...
if GLOB_MODPAR_NAME = "A" then
C=A
PARAMETERS C=C
endif
if GLOB_MODPAR_NAME = "C" then
A=C
PARAMETERS A=A
endif
This way each will be the same as the other but will only change when either of the parameters is changed and not at any other time.
Go to post
2 Replies 2
What about ...
C=A
PARAMETERS C=C
endif
A=C
PARAMETERS A=A
endif
Guru
Ah, so that is what glob_modpar is for. Did not get it when I saw it in the manual.
Thanks,
Ling.
