Repeating components
Hello guys.I've been working with revit for some time and usually used repeated groups..unfortunately in archicad as i understand,groups work completely different...My question would be:is it possible to create set of objects,as example-hotel room with furniture,doors,windows and etc. and copy it few times, as dependent.I mean-if i edit group i copied,other copies would be affected too.if i delete window,it dissapears in every copy i've made?
Thanks!
2 Replies 2
Dwight
research "module"
Dwight Atkinson
Dwight wrote:
research "module"
Thank you,already found out about it.Anyway,they should better make advanced grouping tools,because module system is similar to revit link's-and from own experience....it really annoys when you start linking small objects ,like rooms or something similar..Its more useful if you link whole buildings into model 😕
