Requesting Drawing Window Type
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2009-09-26
04:00 AM
‎2023-05-24
12:39 PM
Rubia Torres
‎2009-09-26
04:00 AM
This is a 2part question:
firstly can you request the window type? (ie Section, Elevation, Interior Elevation, Details) I have created a simple text object but want it to be smart enough to know what kind of window its in & to change parameters accordingly.
also, can you substitute abbreviations for actual text? ie my Elevation Marker reads NE, but in the above created object I want the WndID to come out "NorthEast".
regards.
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-09-26 04:15 AM
‎2009-09-26
04:15 AM
1. I think what you are looking for is... "GLOB_CONTEXT"
2. Depending on the object parameters, you could set a "custom text" in lieu of the ID.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
AC 5.1-25 USA
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-09-26 07:16 AM
‎2009-09-26
07:16 AM
Hi David, Thanks for your advice, I have tried the GLOB_CONTEXT , & it just returns the number 2. I need that to actually read the Window Type.
Can you elborate on the custom text?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-09-26 01:03 PM
‎2009-09-26
01:03 PM
With either or both of these you can determine the situation quite well;
GLOB_CONTEXT contains the info of the active appearance (window)
AC 12 GDL Reference Guide p. 227
AC 12 GDL Reference Guide p. 259
Hope this helps.
Regards, Juha
GLOB_CONTEXT context of appearance 1-library part editor 2-floor plan 3-3D view 4-section/elevation 5-settings dialog 6-list 7 - detail drawing 8 - layout 22 - editing feedback mode from the floor plan 23 - editing feedback mode from a 3Dview 24 - editing feedback mode from a section/elevation 28 - editing feedback mode from a layout 43 - generating as an operator from a 3D view 44 - generating as an operator from a section/elevation 46 - generating as an operator from a listhomeContext contains the info of the placement
REQUEST ("HomeDB_info", "", homeDBIntId, homeDBUserId, homeDBName, homeContext)
Returns in the given variables the internal ID (integer), the user ID and name (strings) of the home database (where the library part containing
this request was placed).
• if placed on the floor plan: the story internal ID, index as a string and name, homeContext = 1
• if placed on a section: the section internal ID, reference IDand name, homeContext = 2
• if placed on a detail: the detail internal ID, reference ID and name, homeContext = 3
• if placed on a master layout: the layout internal ID, empty string and name, homeContext = 4
• if placed on a layout: the layout internal ID, number and name, homeContext = 5
For labels the returned data refers to the labeled element. The collected data can be used to uniquely identify elements in different ArchiCAD databases of a plan file.
Hope this helps.
Regards, Juha
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-09-26 11:05 PM
‎2009-09-26
11:05 PM
You can use the GLOB_CONTEXT like this...
If GLOB_CONTEXT=(#) Then ... (you can script how you want the object to act or fill in a text value parameter to describe the window type)
You can script an If/Then/Else statement to substitute the listed value (ID or custom text parameter) that you are using for your label...
txtLBL=GLOB_ID !(txtLBL text parameter = object ID)
If GLOB_CONTEXT=2 Then !(when viewed from the floor plan window)
txtLBL=custom_text !(txtLBL = custom_text text parameter)
EndIf
PARAMETERS txtLBL=txtLBL !(txtLBL value is reflected in the GUI)
EndIf
AC 5.1-25 USA
AC 5.1-25 USA
