fuzzytnth3 wrote:
Attached below are the wall and window settings
Following on from what s2art said...
What is your floor plan cut plane set at? If it is less than 990 then your window is above your cutplane and therefore not shown - From your screenshot of the settings the window is set 1280 above the base of wall. Base of wall is 290 below the storey level. So the window is 1280-290=990 above the storey level.
I imagine this is probably the case, unless you have the floor cutplane set way to high. If the problem is occurring in the layout book then check your view settings, as the floor cutplane setting can be customised for each view. If not double-check all the other visibility settings to see where it is going. The main thing to remeber is if the window does not cross over your cutplane setting then it will never show.
