Roll up doors
I'm trying to place a roll up door on a project. I tried using a garage door fron the library part but it doesnt have the option to have a roll up cilinder (where door actually rolls up). Is there a Roll up door on the library parts?
10 Replies 10
Laura Yanoviak
A "coiling door"? No. I made my own -- it's not 100%, but might work for you.
Thank you very much, I will try it.
PatriciaLe_o
Hi Laura,
I tried to use your door but whatever I do (like open a section) it appears a missing macro warning... actually it happens twice every time (for 2 lines). Do you know what's wrong here??
Patricia Leão
AC21 INT Full
MacOSHighSierra
Here is a very quick and simple one that I made recently, with no macro calls. The modeling is minimal (at least it's very quick), but it does allow a choice of inset and overlay.
Djordje
You can find them in German and Hungarian libraries of praticular manufacturers. Can't remember where for the life of me now ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I want the same library part some days ago.
Look also here:
http://archicad-talk.graphisoft.com/viewtopic.php?t=15269
Laura Yanoviak
PatriciaLeão wrote:
Hi Laura,
That's a standard AC door/window macro from the US Library -- sorry, I hadn't considered the other libraries.
PatriciaLe_o
No problem Laura. It was a good intention anyway.
Thanks a lot for your door Matthew!
Patricia Leão
AC21 INT Full
MacOSHighSierra
My pleasure. Hope it does the trick for you. The code is also very simple if you feel inclined to tweak it to your needs.
