2008-06-09 07:05 PM
2008-06-09 08:31 PM
2008-06-09 08:31 PM
2008-06-09 09:12 PM
Dave wrote:I think you will need to use a wall, not a column. The column has a profiled cross section on plan, not in section.
....Copy and paste fill into complex profile, new window and check for use as column,set aluminum finish, save as "exhaust fan". Select round column to hgt & radius of fan, with "exhaust fan complex profile" and place in plan.....
2008-06-10 03:21 PM
Peter wrote:
....I think you will need to use a wall, not a column....
2008-08-01 05:51 PM
2008-08-01 07:29 PM
2008-08-01 07:52 PM
Jocelyn wrote:
Why doesn't the column work this way? Why does it show a plan/profile, rather than applying the profile to the column in a way that makes sense? Is there a point? Is this correct for something, or is it just a tool that doesn't work properly?
I was hoping to find a discussion about how to make the profile and column play well together.
2008-08-01 08:26 PM
Jocelyn wrote:The profile applies to the horizontal cross section of a continuous column. The tool is not intended for creating columns that vary over their height, but for its intended purpose it works very well. I know its a bit odd but if you are looking to make classical orders a curved profiled wall is the way to go. Of course this won't give you flutes, scrolls. acanthus leaves nor eggs and darts. For the ornate stuff you need to use library parts (though SEOs can do the trick sometimes).
