ā2010-06-15 11:35 PM
ā2010-06-16 05:11 AM
ā2010-06-16 05:13 AM
ā2010-06-16 05:19 AM
ā2010-06-16 05:20 AM
ā2010-06-16 05:40 AM
ā2010-06-16 07:48 AM
ā2010-06-16 09:04 AM
Dwight wrote:In the parameters page when you're editing the object there are double-headed arrows to drag a parameter up or down in the list to the desired location.
NOTE: adding parameters at the end of the parameter list makes the tilt parameters appear beneath the Parameters for Listing Area.
Dwight wrote:
If i knew more about this newfangled stuff I could direct you better.
ā2010-06-16 12:59 PM
BenY_Boston wrote:Try OBJECTiVE if you want a simple, intuitive way to rotate objects like lamps. To rotate, do the following (referring to the attached image):
Does anyone know how to rotate a standard archiCAD library lamp object (ie. Fluorescent Recessed 02 13) along the x-axis to accommodate a sloped ceiling?
ā2010-06-16 07:10 PM
