Ugljesa Janjic
Rotating object around x and y axes
Hello all,
How can I rotate an object, a slab or a library element, around its y axis?
I created an object and saved it in the library but the orientation is not right.
Any help is good. Thank you.
Ugljesa Janjic
[email protected]
ArchiCAD 25
Mac OS
3 Replies 3
Ralph Wessel
Try OBJECTiVE - it provides tools to rotate any selection of GDL objects.
Ralph Wessel BArch
Central Innovation
Ugljesa wrote:
Hello all,
If you don't know GDL, OBJECTIVE is the answer, and it also sorts out the 2D, but if you say you wrote the object you could apply a parametric ROTy to the whole 3d and a Project2 to the 2D.
However, if you created the object with Archicad tools (and not with GDL), then you can't do a ROTy because the object may have been created hundreds of meters from the origin. Move the AC tools that made your object to a position over the Origin, create it again, and theres a chance that you can apply a ROTy to it, providing you write a PROJECT2 3,270,2 statement into the 2D script. make it on Ground level too!!!
I made a object to rotate anything, you can download in my web: http://www.garquitectos.es/index.php/archicad/objetos-gratuitos.html its in Spanish but its very easy to use, I have upload a tutorial in YouTube in my channel. I will redesigned my web soon and I will erase the "archicad" pages, so if you want ... Hurry up!
