2012-07-19 12:00 AM
2012-07-19 07:56 AM
Ugljesa wrote:Try OBJECTiVE - it provides tools to rotate any selection of GDL objects.
How can I rotate an object, a slab or a library element, around its y axis?
2012-07-19 11:08 AM
Ugljesa wrote:If you don't know GDL, OBJECTIVE is the answer, and it also sorts out the 2D, but if you say you wrote the object you could apply a parametric ROTy to the whole 3d and a Project2 to the 2D.
Hello all,
I created an object and saved it in the library but the orientation is not right.
Any help is good. Thank you.
2012-07-24 11:37 AM
