Rough Opening Extra in AC9 Special Edition Library
There is a setting for Rough Opening Extra in the Doors and Windows of the AC9 Special Edition Library. We would like to be able to turn this feature off. If we use zero as the value the door or window generates an error message. We put the value 1/64" in but we would rather shut the Rough Opening Extra feature off.
Is there a way to turn off the Rough Opening Extra in AC9 Special Edition Library?
Thank you,
John
I've set this value to zero (typically) without any errors. What wall type are you specifying?
Matthew,
I'm having the problem with either a Solid or Stud wall Setting. The problem occurs when I try to open a section/elevation or 3D view.
I'm attaching a sample file with a door and window. If I change either the door or windows rough opening settings to zero and try to open any of the section/elevation views I get an error message.
I would really like to be able to shut the Rough Opening Extra to OFF.
Aloha,
John
