ā2004-05-16 06:40 PM
ā2004-05-18 02:34 AM
ā2004-05-18 03:30 AM
ā2004-05-18 09:29 PM
ā2004-05-18 10:40 PM
ā2004-05-18 11:06 PM
ā2004-05-19 02:31 AM
ā2004-05-20 01:00 AM
ā2004-08-13 03:47 AM
Oleg wrote:i"ve both SO_Renumber.gsm and Master_gdl.gdl loaded but not working! what have i done wrong?Peter wrote:You can delete all files excluding SO_Renumber.gsm and Master_gdl.gdl
Oleg,
In the SO_Renumber.LIB there are two files with
file extensions *.gd& and *.gs&.
What kind of file types are these ?
I did a search in Archicad Help and came up with nothing.
If the part uses DATA IO does something have be put in
what was in AC 6.5 called "Archicad data folder" ?
If so what is the name of the corresponding folder
in AC 8.1 v2 ?
Thank you,
Peter Devlin
gd& and gs& files are precompiled scripts on the Windows platform. They are created automatically by ArchiCAD.
DATA IO uses by default ArchiCAD root folder (instead of "ArchiCAD Data Folder" for TEXT IO).
You should not put any files into it. Two files will be created by the object automatically.
The note:
I do not know why Chadi writes about Alt+click. As far as I remember, for renumbering elements (after deleting for example) it is required to use Alt+Rebuld.
Besides this object was something like idea to share for GDL developers (One more same object was SO_Animation). Though it was working object, I am not sure in its practical utility.
ā2004-08-15 04:34 AM
ā2004-08-15 09:03 AM
Peter wrote:hi, Peter
LiHigh,
Would you please describe in what way the object does not work.
What way did you expect it to work?
Peter Devlin
