We value your input!
Saved an object in AC 10 - now unusable in 9???
This is not good. Someone please tell me that there is a method to save objects in 10 and make them usable in 9 and vice-versa.
10 REPLIES 10
Ralph Wessel
Mentor
F. wrote:
But you will need the recent versions of the XML converter for downgrading, isn't it? The actual downloadable one will create objects for AC10 (Version 21 or 22 I guess).
There is a version of the converter for every version of ArchiCAD from 8 to 10. Each produces objects suited to its corresponding ArchiCAD version, but the XML source may have come from any other version. For example, I could convert an AC10 object to XML using the AC10 converter, and then convert the XML to an AC8 object using the AC8 converter.
Ralph Wessel BArch
Software Engineer Speckle Systems
