2011-07-12 03:35 AM
2011-07-12 05:55 PM
Baby wrote:No problems here, and I'm on a Mac as well. Maybe I am not reproducing exactly what you did though.... I made a cube with two slabs and four walls. I selected these elements and saved from plan (File > Libraries and Objects > Save Selection As...) and I also saved as an object from 3D - once with the Options set for binary, the other time for Editable.
Every time when i create simple 3D object like cube box (using wall and slab elements) and when i save the 3D object from 3D plan view, that particular library file size can go up to 100MB.
i also test it on different elements like create simple handrail (using beam tool) and the library file size is 130MB when i save the 3D object.
Its that the AC15 bugs?
2011-07-13 03:54 AM
2011-07-13 06:12 AM
Karl wrote:Thank you for the reply, i believe is the build 3003 bug. i repeat again what you have done and i got 20kb if i saved object from plan but when i saved the same object from 3D, i got 130 mbBaby wrote:No problems here, and I'm on a Mac as well. Maybe I am not reproducing exactly what you did though.... I made a cube with two slabs and four walls. I selected these elements and saved from plan (File > Libraries and Objects > Save Selection As...) and I also saved as an object from 3D - once with the Options set for binary, the other time for Editable.
Opening Library Manager and looking at the size of each of the three saved objects, I see:
17 kb - object saved from plan
63 kb - binary object saved from 3D
14 kb - editable (GDL script) saved from 3D
All seems normal to me... So, either it is because I am on Build 3006 (and perhaps you are using 3003?) or I am not doing exactly what you did...
2011-07-13 06:17 AM
Barry wrote:Thank you Barry, its work. i manage to reduce the file size to 15K. Thanx a lot
Baby Boon,
Does this help at all?
http://www.archicadwiki.com/Bugs/FileSizeGrowingWhenBinaryObjectsInEmbeddedLibrary
