fuzzytnth3
Script error
The script below is kicking up an error saying that Keywords cannot be used as variables. For the life of me I can't see what I've done wrong so if some kind soul could take a look with a fresh pair of eyes that would be much appreciated.
VALUES "knlist" "Click here",
"101 Western Red Cedar cladding ",
"102 Sliding glass door",
"103 Existing windows and wall removed and new steel beams installed",
"104 New Kitchen fittings and island unit",
"105 Double glazed aluminium 'stick' system",
"106 New stair",
"107 New stone paved area",
"108 New RWP connection",
"109 Existing opening built up ",
"110 Existing wall removed and new beam fitted",
"111 Fit lead flashing and make good slates as required",
"112 Lead flashing extended"
Using AC25 5005 UKI FULL
4 Replies 4
Frank Beister
Not for me in AC10.
fuzzytnth3
weird I'm using ArchiCAD 10 as well but the text refuses to show correctly and kicks up the error.
I'm going to try quitting ArchiCAD and restarting the machine and see if that makes a difference.
Frank Beister
Try it in a plain object. Sometimes the error messages of the precomiler do not have to do anything with the real mistake, if there is one anyway.
vfrontiers
I've got a bug that I could use some help fixing...
In W Beams 10, the 2d script is not using the FILL PEN when the beam is inclined....
It would appear this PROJECT2 {2} command does not allow for unique CONTOUR and FILL pens.
Anyone?
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
