Jefferson
Can window parameters transfer different window types?
Migrating from 8.1 to 10........somewhere between 8.1 and 10, I seem to recall the advertised ability, [maybe in 9], to transfer parameters, the trim/appearance, line + fill, + marker settings between DIFFERENT window types, being the ones I'm after, say a single hung and then a casement, generating a uniform look, in plan, sections + elevations, without having to work your way through all the settings for every window.
But.........I cannot find the documentation [read instructions] for this. Was it a dream? If this is indeed possible can some kind soul point me in the right direction please.
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
8 Replies 8
David Pacifico
It works as long as the windows have the same parameters.
Select a window
Open the window settings
Find the other window that you want to transfere the parameters to.
Ctrl-Alt Click on the window preview in the lower left corner of the dialog box.
David Pacifico, RA
AC27 iMac i9, 32 gig Ram, 8 gig video Ram
Jefferson
That was a GOOD dream! I feel like I just got a raise!
Thanks David!
jeff white
w3d design
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
Wow..... How did I miss this until now? I too feel like I got a raise.
Thanks
Jefferson
Steve -
Cool avatar! Appropriate to ths forum and very original.
jeff white
w3d design
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
Thanks.
I was just trying to avoid using a picture of me....
vfrontiers
While we're getting all escited, I wonder if someone could verify this for me....
On both Windows and doors (and stee beams), if you parameter transfer from a casement to an awning... you still get a casement!... If you parameter transfer from a Single Door to a Double Door... you still get a single door! If you parameter transfer from a TUBE STEEL BEAM to a WIDE FLANGE... you still get a TUBE STEEL BEAM...
Anyone?
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
I'm still in 9 (Special Addition Library), but it seems to change from an awning to a casement or a wide flange to a tube...... and even a single to double door. I'll admit they get a little weird. The double door went from a 3070 to a dbl door w/ one 6" leaf and one 2'-6", but it seems like most of the parameters transferred and the leaf thing is an easy fix... I haven't done a lot with it yet, but I still like that some of the parameters change even if I have to tweak them. Ultimately it still saves me time.....
vfrontiers wrote:
While we're getting all escited, I wonder if someone could verify this for me....If you parameter transfer from a TUBE STEEL BEAM to a WIDE FLANGE... you still get a TUBE STEEL BEAM...
Parameter transfer works by transferring values when the internal parameter names match exactly. In those two beams, the shape is internally called 'Profile'. The Shapes' parameter lists have CUSTOM in them, so there's nothing to stop the user, or the transfer thing, from putting a TS shape name in a W beam object. Check out the 3D and you see that it is in fact a W, made with the 'Dimensions' parameters. The names match here too: 'ws', 'ds', and 'wt'. So it's keeping the name string and the dimensions and doing its best, never mind that it's nonsense.
If you change the shape spec after transferring, the dims will correct themselves.
IMO the shape name and the dims should have the 'Unique Parameter' (U) button pressed inside the library part; with this on, a given parameter won't transfer. For the beams, you should have to choose the shape, while it keeps the cut planes, 2D settings, etc. This is GS's mistake.
I assume the doors are similar but I didn't look. The important thing is the internal name of the parameter, and the 'U' button.
James Murray
