JGoode
Set Fill Origin
Hello,
Is it possible to be able to set a fill origin? Like the slab cover fills?
Thanks
ArchiCAD 27
Windows 10
1 Solution
I think the POLY2_B{2} command has options for fill origin and angle, but I have never used it. Good luck!
Go to post
7 Replies 7
Eduardo Rolon
Yes,
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
JGoode
Is this for an object?
ArchiCAD 27
Windows 10
Eduardo Rolon
Nope, sorry. Didn't look at the Board section. Oops
AC29 US/INT -> AC08
JGoode
No worries
ArchiCAD 27
Windows 10
Yes that is correct.
You can even create a graphical hotspot for the origin co-ordinates so you can drag it around in plan.
Barry
JGoode
Excellent! Thank you very much
ArchiCAD 27
Windows 10
