Set a maximum value based on glob_scale
JGoode
I want to be able to set the value of a parameter but I can't use glob_scale in the parameter scripts and I can't use values in the 2D script. How can I work around this?
Thanks
ArchiCAD 23
Windows 10
1 REPLY 1
I don't think you can.
Imagine you have two elevation views showing the same object but with different scales.
Which one sets the max parameter value for the object?
