‎2014-11-14
12:34 PM
‎2023-05-24
12:32 PM
Rubia Torres
HOTSPOT2 x,y !upper left corner of the marker HOTSPOT2 x,y !upper right corner of the marker HOTSPOT2 x,y !bottom left corner of the marker HOTSPOT2 x,y !bottom right corner of the marker WINDOW ID !The name of the LIBRARY PART not the ID from "Tags&Categories" ROUGH OPENING OF THE WINDOW !Separated with an "X" symbol CUSTOM TEXT 1 (OPTIONAL) CUSTOM TEXT 2 (OPTIONAL) CUSTOM TEXT 3 (OPTIONAL)Finally, in order the marker to placed properly according to the window position, the script must recognize if "CUSTOM TEXT" is present in order to rearrange the hotspots.
‎2014-11-14 04:45 PM
‎2014-11-14 05:03 PM
‎2014-11-16 09:36 PM
if iIDText = VALUE_AUTOMATIC then strIDValue = AC_WIDO_IDand also I found this inside Scripts/Parameter
! ============================================================================= ! ID ! ============================================================================= values "strIDText" stAutoCustom values "iIDText" VALUE_AUTOMATIC, VALUE_CUSTOM if GLOB_MODPAR_NAME = "strIDText" then iIDText = VALUE_AUTOMATIC if strIDText = stAutoCustom[2] then iIDText = VALUE_CUSTOM parameters iIDText = iIDText else strIDText = stAutoCustom[1] if iIDText = VALUE_CUSTOM then strIDText = stAutoCustom[2] parameters strIDText = strIDText endif if iIDText = VALUE_AUTOMATIC then ! automatic ! strIDValue got value in master script parameters strIDValue = strIDValue lock "strIDValue" endifmy problem is that I need the ID to use the name from the library part and not from "Tags&Categories" inside the window. Any ideas??
! Fill box array, get stamp width
dim strings2d[][2]
dim lengthValues2d[][2]
dim dimensionType[]
numLinesInBox = bShowWallholeDim + bShowUnitDim + bShowFire + bShowAcoustic + \
bShowUValue + bShowMaterial + bShowHardware
if bWindow then
numLinesInBox = numLinesInBox + bShowRevealDim + bShowSill + bShowCust1 + bShowCust2
else
numLinesInBox = numLinesInBox + bShowEgressDim + bShowThreshold + bShowHandle + bShowCust
endif
if numLinesInBox > 0 then
strings2d[numLinesInBox][2] = ""
lengthValues2d[numLinesInBox][2] = -9999
dimensionType[numLinesInBox] = 0
endif
style "boxStyleLeft"
boxSpaceWidth = stw(" ") / 1000 * GLOB_SCALE
actLine = 1
columnWidth = 0
if bShowWallholeDim then
if iWHDimText = DIM_MEASURED then
strings2d[actLine][1] = strWHPrefix
strings2d[actLine][2] = ""
lengthValues2d[actLine][1] = wallholeWidth
lengthValues2d[actLine][2] = wallholeHeight
dimensionType[actLine] = UNITTYPE_WIDO_DIM
else
strings2d[actLine][2] = strWHDimValue
lengthValues2d[actLine][1] = 0
lengthValues2d[actLine][2] = 0
dimensionType[actLine] = 0
endif
columnWidth = max(columnWidth, stw(" " + strWHPrefix + " "))
columnWidth = max(columnWidth, stw(" " + strWHDimValue + " "))
actLine = actLine + 1
endif
if bShowUnitDim then
if iUnitDimText = DIM_MEASURED then
strings2d[actLine][1] = strUnitPrefix
lengthValues2d[actLine][1] = unitWidth
lengthValues2d[actLine][2] = unitHeight
else
strings2d[actLine][2] = strUnitDimValue
endif
columnWidth = max(columnWidth, stw(" " + strUnitPrefix + " "))
columnWidth = max(columnWidth, stw(" " + strUnitDimValue + " "))
endif
if bWindow and bShowRevealDim then
if iRevealDimText = DIM_MEASURED then
strings2d[actLine][1] = strRevealPrefix
lengthValues2d[actLine][1] = revealWidth
lengthValues2d[actLine][2] = revealHeight
else
strings2d[actLine][2] = strRevealDimValue
endif
columnWidth = max(columnWidth, stw(" " + strRevealPrefix + " "))
columnWidth = max(columnWidth, stw(" " + strRevealDimValue + " "))
endif
if not(bWindow) and bShowEgressDim then
if iEgressDimText = DIM_MEASURED then
strings2d[actLine][1] = strEgressPrefix
lengthValues2d[actLine][1] = egressWidth
lengthValues2d[actLine][2] = egressHeight
else
strings2d[actLine][2] = strEgressDimValue
endif
columnWidth = max(columnWidth, stw(" " + strEgressPrefix + " "))
columnWidth = max(columnWidth, stw(" " + strEgressDimValue + " "))
endif
if bWindow and bShowSill then
if iSillText = DIM_MEASURED then
strings2d[actLine][1] = strSillPrefix
lengthValues2d[actLine][1] = sillHeight
dimensionType[actLine] = UNITTYPE_SILL_DIM
else
strings2d[actLine][2] = strSillValue
endif
columnWidth = max(columnWidth, stw(" " + strSillPrefix + " "))
columnWidth = max(columnWidth, stw(" " + strSillValue + " "))
endif
if not(bWindow) and bShowThreshold then
if iThresholdText = DIM_MEASURED then
strings2d[actLine][1] = strThresholdPrefix
lengthValues2d[actLine][1] = thresholdHeight
else
strings2d[actLine][2] = strThresholdValue
endif
columnWidth = max(columnWidth, stw(" " + strThresholdPrefix + " "))
columnWidth = max(columnWidth, stw(" " + strThresholdValue + " "))
endif
if bShowFire then
strings2d[actLine][1] = strFirePrefix
strings2d[actLine][2] = strFireValue
columnWidth = max(columnWidth, stw(" " + strFirePrefix + " "))
columnWidth = max(columnWidth, stw(" " + strFireValue + " "))
endif
if bShowAcoustic then
strings2d[actLine][1] = strAcousticPrefix
strings2d[actLine][2] = strAcousticValue
columnWidth = max(columnWidth, stw(" " + strAcousticPrefix + " "))
columnWidth = max(columnWidth, stw(" " + strAcousticValue + " "))
endif
if bShowUValue then
strings2d[actLine][1] = strUValuePrefix
strings2d[actLine][2] = strUValueValue
columnWidth = max(columnWidth, stw(" " + strUValuePrefix + " "))
columnWidth = max(columnWidth, stw(" " + strUValueValue + " "))
endif
if bShowMaterial then
strings2d[actLine][1] = strMaterialPrefix
strings2d[actLine][2] = strMaterialValue
columnWidth = max(columnWidth, stw(" " + strMaterialPrefix + " "))
columnWidth = max(columnWidth, stw(" " + strMaterialValue + " "))
endif
if bShowHardware then
strings2d[actLine][1] = strHardwarePrefix
strings2d[actLine][2] = strHardwareValue
columnWidth = max(columnWidth, stw(" " + strHardwarePrefix + " "))
columnWidth = max(columnWidth, stw(" " + strHardwareValue + " "))
endif
if bWindow and bShowCust1 then
strings2d[actLine][1] = strCust1Prefix
strings2d[actLine][2] = strCust1Value
columnWidth = max(columnWidth, stw(" " + strCust1Prefix + " "))
columnWidth = max(columnWidth, stw(" " + strCust1Value + " "))
endif
if bWindow and bShowCust2 then
strings2d[actLine][1] = strCust2Prefix
strings2d[actLine][2] = strCust2Value
columnWidth = max(columnWidth, stw(" " + strCust2Prefix + " "))
columnWidth = max(columnWidth, stw(" " + strCust2Value + " "))
endif
if not(bWindow) and bShowHandle then
strings2d[actLine][1] = strHandlePrefix
strings2d[actLine][2] = strHandleValue
columnWidth = max(columnWidth, stw(" " + strHandlePrefix + " "))
columnWidth = max(columnWidth, stw(" " + strHandleValue + " "))
endif
if not(bWindow) and bShowCust then
strings2d[actLine][1] = strCustPrefix
strings2d[actLine][2] = strCustValue
columnWidth = max(columnWidth, stw(" " + strCustPrefix + " ")) ! mm, paper size
columnWidth = max(columnWidth, stw(" " + strCustValue + " "))
endif
style "headerStyle"
IDWidth = stw(" " + strIDValue + " ") ! mm, paper size
IDSpaceWidth = stw(" ") / 1000 * GLOB_SCALE
minStampWidth = max(IDWidth, 2 * columnWidth) ! mm, paper size
n = request("Height_of_style", "headerStyle", sh)
minIDLineSpacing = sh ! mm, paper size
n = request("Height_of_style", "boxStyleLeft", sh)
minDetailLineSpacing = sh ! mm, paper size
if iStampWidth = VALUE_AUTOMATIC then
stampWidth = minStampWidth / 1000 * GLOB_SCALE
else
stampWidth = stampWidth_mm / 1000 * GLOB_SCALE
endif
if iIDLineSpacing = VALUE_AUTOMATIC then
headerHeight = minIDLineSpacing / 1000 * GLOB_SCALE
else
headerHeight = IDLineSpacing_mm / 1000 * GLOB_SCALE
endif
if iDetailLineSpacing = VALUE_AUTOMATIC then
lineHeight = minDetailLineSpacing / 1000 * GLOB_SCALE
else
lineHeight = detailLineSpacing_mm / 1000 * GLOB_SCALE
endif
stampHeight = headerHeight + numLinesInBox * lineHeight
I found also some code inside scripts/interface that refers to Custom Text 1&2
! Content by Scale
ui_page 1
y = y0
y2 = y0 + 130
dy = 20
x0 = 1
x1 = 215
xsep = 222
x2 = 230
x3 = 443
xwidth = 136
ui_style 0, 1
ui_outfield `Detail Level`, x0, y, 100, 16
ui_infield{3} "iDetLevel", x0+101, y, 150, 16,
8, "",
0, 0,
cx, cy, px, py,
"", stDetLevels[1], DETLEV_SCALESENS,
"", stDetLevels[2], DETLEV_DETAILED,
"", stDetLevels[3], DETLEV_SIMPLE
y = y + dy + 1
ui_separator 0, y, 444, y
ui_separator 0, y2 - 4, 444, y2 - 4
y = y + 4
if bMetricDimensionNeeded then
ui_outfield `Show up to 1:50`, x0, y, x1-x0-1, 16
ui_outfield `Show from 1:50`, x0, y2, x3-x2-1, 16
else
ui_outfield `Show in Detailed`, x0, y, x1-x0-1, 16
ui_outfield `Show in Middle and Simple`, x0, y2, x3-x2-1, 16
endif
ui_style 1, 0
dim paramNames[3][4]
paramNames[1][1] = "bShowID" ! "bShowID_detailed" "bShowID_simple"
paramNames[1][2] = "bShowWallholeDim" ! "bShowWallholeDim_detailed" "bShowWallholeDim_simple"
paramNames[1][3] = "bShowUnitDim" ! "bShowUnitDim_detailed" "bShowUnitDim_simple"
if bWindow then
paramNames[1][4] = "bShowRevealDim" ! "bShowRevealDim_detailed" "bShowRevealDim_simple"
paramNames[2][1] = "bShowSill" ! "bShowSill_detailed" "bShowSill_simple"
else
paramNames[1][4] = "bShowEgressDim" ! "bShowEgressDim_detailed" "bShowEgressDim_simple"
paramNames[2][1] = "bShowThreshold" ! "bShowThreshold_detailed" "bShowThreshold_simple"
endif
paramNames[2][2] = "bShowFire" ! "bShowFire_detailed" "bShowFire_simple"
paramNames[2][3] = "bShowAcoustic" ! "bShowAcoustic_detailed" "bShowAcoustic_simple"
paramNames[2][4] = "bShowUValue" ! "bShowUValue_detailed" "bShowUValue_simple"
paramNames[3][1] = "bShowMaterial" ! "bShowMaterial_detailed" "bShowMaterial_simple"
paramNames[3][2] = "bShowHardware" ! "bShowHardware_detailed" "bShowHardware_simple"
if bWindow then
paramNames[3][3] = "bShowCust1" ! "bShowCust1_detailed" "bShowCust1_simple"
paramNames[3][4] = "bShowCust2" ! "bShowCust2_detailed" "bShowCust2_simple"
else
paramNames[3][3] = "bShowHandle" ! "bShowHandle_detailed" "bShowHandle_simple"
paramNames[3][4] = "bShowCust" ! "bShowCust_detailed" "bShowCust_simple"
endif
dim paramDesc[3][4]
paramDesc[1][1] = `ID`
paramDesc[1][2] = `Wallhole Dimensions`
paramDesc[1][3] = `Unit Dimensions`
if bWindow then
paramDesc[1][4] = `Reveal Dimensions`
paramDesc[2][1] = `Sill Height`
else
paramDesc[1][4] = `Egress Dimensions`
paramDesc[2][1] = `Threshold Height`
endif
paramDesc[2][2] = `Fire Rating`
paramDesc[2][3] = `Acoustic Rating`
paramDesc[2][4] = `U-value`
paramDesc[3][1] = `Material`
paramDesc[3][2] = `Hardware Set`
if bWindow then
paramDesc[3][3] = `Custom Text 1`
paramDesc[3][4] = `Custom Text 2`
else
paramDesc[3][3] = `Handle`
paramDesc[3][4] = `Custom Text`
endif
y = y + dy - 1
y2 = y2 + dy - 1
for i = 1 to 3
for j =1 to 4
NameSuffix = "_detailed"
ypos = y
for k =1 to 2
ui_infield{4} paramNames + NameSuffix, x0, ypos, xwidth, 16,
7, "",
0, 0,
0, 0, 0, 0,
"", paramDesc, 0,
"", paramDesc, 1
NameSuffix = "_simple"
ypos = y2
next k
y = y + dy
y2 = y2 + dy
next j
x0 = x0 + 148
y = 76
y2 = y +105
if i < 3 then
ui_separator x0 - 5 , y, x0 - 5, y - 5 + 4*dy
ui_separator x0 - 5 , y2, x0 - 5, y2 - 5 + 4*dy
endif
next i
!ui_infield{3} "bShowID_detailed", x0, y, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! "", `ID`, 0,
! "", `ID`, 1
!ui_infield{3} "bShowID_simple", x0, y2, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! "", `ID`, 0,
! "", `ID`, 1
!y = y + dy
!y2 = y2 + dy
!ui_infield{3} "bShowWallholeDim_detailed", x0, y, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! "", `Wallhole Dimensions`, 0,
! "", `Wallhole Dimensions`, 1
!ui_infield{3} "bShowWallholeDim_simple", x0, y2, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
!y = y + dy
!y2 = y2 + dy
!ui_infield{3} "bShowUnitDim_detailed", x0, y, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! "", `Unit Dimensions`, 0,
! "", `Unit Dimensions`, 1
!ui_infield{3} "bShowUnitDim_simple", x0, y2, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
!y = y + dy
!y2 = y2 + dy
!if bWindow then
! ui_infield{3} "bShowRevealDim_detailed", x0, y, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! "", `Reveal Dimensions`, 0,
! "", `Reveal Dimensions`, 1
! ui_infield{3} "bShowRevealDim_simple", x0, y2, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! y = y + dy
!else
! ui_infield{3} "bShowEgressDim_detailed", x0, y, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! "", `Egress Dimensions`, 0,
! "", `Egress Dimensions`, 1
! ui_infield{3} "bShowEgressDim_simple", x0, y2, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
!endif
!x0 = x0 + 148
!y = 76
!y2 = y +105
!ui_separator x0 - 5 , y, x0 - 5, y - 5 + 4*dy
!ui_separator x0 - 5 , y2, x0 - 5, y2 - 5 + 4*dy
!if bWindow then
! ui_infield{3} "bShowSill_detailed", x0, y, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! "", `Sill Height`, 0,
! "", `Sill Height`, 1
! ui_infield{3} "bShowSill_simple", x0, y2, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
!else
! ui_infield{3} "bShowThreshold_detailed", x0, y, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! "", `Threshold Height`, 0,
! "", `Threshold Height`, 1
! ui_infield{3} "bShowThreshold_simple", x0, y2, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
!endif
!y = y + dy
!y2 = y2 + dy
!ui_infield{3} "bShowFire_detailed", x0, y, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! "", `Fire Rating`, 0,
! "", `Fire Rating`, 1
!ui_infield{3} "bShowFire_simple", x0, y2, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
!y = y + dy
!y2 = y2 + dy
!ui_infield{3} "bShowAcoustic_detailed", x0, y, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! "", `Acoustic Rating`, 0,
! "", `Acoustic Rating`, 1
!ui_infield{3} "bShowAcoustic_simple", x0, y2, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
!y = y + dy
!y2 = y2 + dy
!ui_infield{3} "bShowUValue_detailed", x0, y, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! "", `U-value`, 0,
! "", `U-value`, 1
!ui_infield{3} "bShowUValue_simple", x0, y2, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! "", `U-value`, 0,
! "", `U-value`, 1
!x0 = x0 + 148
!y = 76
!y2 = y +105
!ui_infield{3} "bShowMaterial_detailed", x0, y, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! "", `Material`, 0,
! "", `Material`, 1
!ui_infield{3} "bShowMaterial_simple", x0, y2, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! "", `Material`, 1
!y = y + dy
!y2 = y2 + dy
!ui_infield{3} "bShowHardware_detailed", x0, y, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! "", `Hardware Set`, 0,
! "", `Hardware Set`, 1
!ui_infield{3} "bShowHardware_simple", x0, y2, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
!y = y + dy
!y2 = y2 + dy
!if bWindow then
! ui_infield{3} "bShowCust1_detailed", x0, y, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! "", `Custom Text 1`, 0,
! "", `Custom Text 1`, 1
! ui_infield{3} "bShowCust1_simple", x0, y2, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
!else
! ui_infield{3} "bShowHandle_detailed", x0, y, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! "", `Handle`, 0,
! "", `Handle`, 1
! ui_infield{3} "bShowHandle_simple", x0, y2, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! "", `Handle`, 0,
! "", `Handle`, 1
!endif
!y = y + dy
!y2 = y2 + dy
!if bWindow then
! ui_infield{3} "bShowCust2_detailed", x0, y, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! "", `Custom Text 2`, 0,
! "", `Custom Text 2`, 1
! ui_infield{3} "bShowCust2_simple", x0, y2, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
!else
! ui_infield{3} "bShowCust_detailed", x0, y, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
! "", `Custom Text`, 0,
! "", `Custom Text`, 1
! ui_infield{3} "bShowCust_simple", x0, y2, xwidth, 16,
! 7, "",
! 0, 0,
! 0, 0, 0, 0,
!endif
and
! Content 3
ui_page 4
y = 40
dy = 27
x1 = 1
x2 = 15
x3 = 180
x4 = 310
x5 = 325
x6 = 440
ui_style 0, 1
ui_outfield `Material`, x1, y, x3-x1-1, 18
ui_style 0, 0
ui_infield{3} "iMaterialText", x3, y-3, x4-x3, 20,
8, "",
0, 0,
0, 0, 0, 0,
"", stMaterials[1], 1,
"", stMaterials[2], 2,
"", stMaterials[3], 3,
"", stMaterials[4], 4
ui_infield "strMaterialValue", x5, y-3, x6-x5, 20
y = y + dy
ui_outfield `Item Name`, x2, y, x3-x2-1, 18
ui_infield "strMaterialPrefix", x3, y-3, x4-x3, 20
y = y + dy
ui_style 0, 1
ui_outfield `Hardware Set`, x1, y, x3-x1-1, 18
ui_style 0, 0
ui_infield{3} "iHardwareText", x3, y-3, x4-x3, 20,
8, "",
0, 0,
0, 0, 0, 0,
"", stAutoCustom[1], VALUE_AUTOMATIC,
"", stAutoCustom[2], VALUE_CUSTOM
ui_infield "strHardwareValue", x5, y-3, x6-x5, 20
y = y + dy
ui_infield "strHardwarePrefix", x3, y-3, x4-x3, 20
y = y + dy
if bWindow then
ui_style 0, 1
ui_outfield `Custom Text 1`, x1, y, x3-x1-1, 18
ui_style 0, 0
ui_outfield `Item Name 1`, x3, y, x4-x3, 20
ui_infield "strCust1Prefix", x5, y-3, x6-x5, 20
y = y + dy
ui_outfield `Text 1`, x3, y, x4-x3, 20
ui_infield "strCust1Value", x5, y-3, x6-x5, 20
y = y + dy
ui_style 0, 1
ui_outfield `Custom Text 2`, x1, y, x3-x1-1, 18
ui_style 0, 0
ui_outfield `Item Name 2`, x3, y, x4-x3, 20
ui_infield "strCust2Prefix", x5, y-3, x6-x5, 20
y = y + dy
ui_outfield `Text 2`, x3, y, x4-x3, 20
ui_infield "strCust2Value", x5, y-3, x6-x5, 20
y = y + dy
else
ui_style 0, 1
ui_outfield `Handle`, x1, y, x3-x1-1, 18
ui_style 0, 0
ui_outfield `Item Name`, x3, y, x4-x3, 20
ui_infield "strHandlePrefix", x5, y-3, x6-x5, 20
y = y + dy
ui_outfield `Text`, x3, y, x4-x3, 20
ui_infield "strHandleValue", x5, y-3, x6-x5, 20
y = y + dy
ui_style 0, 1
ui_outfield `Custom Text`, x1, y, x3-x1-1, 18
ui_style 0, 0
ui_infield "strCustPrefix", x5, y-3, x6-x5, 20
y = y + dy
ui_infield "strCustValue", x5, y-3, x6-x5, 20
y = y + dy
endif
I know I'm asking tooo much but if someone has the time and the mood to have a look, I would really appreciate it!!!‎2014-11-19 04:12 PM
‎2014-11-19 06:00 PM
REQUEST ("ASSOCLP_NAME", "", name)
in the GDL reference guide (and the other request functions) to see if it is what you need.‎2014-11-19 08:39 PM
objectid = "" !objectid is a random name that I picked
rrr = request("LIBRARY_PART_NAME", "", name)
if rrr then objectid = name
strIDValue = objectid
endif
The question that I have now is: should I create also a parameter on the objects parameters window for any of the "LIBRARY_PART_NAME" / "name" and "objectid" ?if rrr then objectid = nameThanks for your patience!
‎2014-11-19 09:45 PM
that may stand for "ASSOCiatedLibraryPart_NAME" if I'm not mistakenREQUEST ("LIBRARY_PART_NAME", "", name)
which I don't think exists.if iIDText = VALUE_AUTOMATIC then strIDValue = AC_WIDO_IDSo in master script, add the request before the line if you want it to show the library part name instead of the window ID:
name=""
rrr = request("ASSOCLP_NAME", "", name)
if iIDText = VALUE_AUTOMATIC then strIDValue = name
Beware this may break something else. ‎2014-11-19 10:30 PM
‎2014-11-19 10:58 PM
