fuzzytnth3
Sink General 14 glitch
Hi grasping at straws here but I don't suppose anyone out there has fixed the glitch in the Sink General 14 library object? The glitch appears when you select the Sink Style 13 (funnily enough )
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
8 Replies 8
Rod Jurich
Cannot reproduce, see attached.
I will upload my library part for you next post.
EDIT: change the length and yes, what you show happens.
I will open and edit part and upload when correct.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Rod Jurich
....................... there is a bug in the macro CALL "fa_sinktyp" Parameters ALL
It will take a while to find.
Rod Jurich
Rod Jurich
.................. style 11 & 12 is also affected
Rod Jurich
Rod Jurich
Fixed as last. If you want to do this yourself the open a macro named fa_sinktyp
You will find in the Folder named Furniture Macros 14
See attached pic where the value given as a should read as 1.5
This is the same for type 11, 12 & 13
............ OR d'load the macro which I will post next.
Rod Jurich
Rod Jurich
..................... and the edited macro.
Rod Jurich
fuzzytnth3
Wow Rod I go home for tea and go to bed come back to work and you've sorted it all out!
Brilliant thanks!
Rod Jurich
fuzzytnth3 wrote:
/...........Brilliant thanks!
................. not quite, just happy to assist.
Rod Jurich
I just checked it, and fortunately, in ArchiCAD 15 it is already fixed.
