Steve Jepson
SketchUp to ArchiCAD 14
Can someone please convert this SketchUp file into a .gsm or .3ds part for me.
Thanks.
4 Replies 4
No time today... so somebody else may do it ... but since your signature says you are on Windows, I'm wondering why you cannot do this yourself? Would the add-on not install for you?
Steve Jepson
Good question. I thought about putting some info about that in the post but was in a hurry at the time.
I am am using the 64bit version of ArchiCAD 14 and the ArchiCAD-Google Earth Connection Plug-in only works with the 32bit version. I could do it in SketchUp but I don't have the Pro version with the converter add-on's.
I could also do it if I wanted to install the 32bit version of ArchiCAD but I am running out of room on my hard drive.
http://www.graphisoft.com/products/archicad/addons/google_earth/ge_earth_connections_download.html
vfrontiers
Download Sketchup PRO trial version...
Open file up in sketchup Pro and save as .3ds
Use ArchiCAD's 3ds to gsm convertor (presuming that's available for 14 / 64bit)..
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
Steve Jepson
did that. Works fine
