Sketchup Component
Hi! I wonder how to give a GDL-object from a sketchup6 "component"
a cut fill?
Is this possible?
Tanks for any answer !!!!
4 Replies 4
a cut fill?
Is this possible?
Mats_Knutsson
Mentor
a cut fill?
Is this possible?
Hi Markus,
You should specify if you want to do a dumb export from Sketchup (component -> gdl object) or a smart export (construction elements in ArchiCAD). Smart export - njema promlema. Dumb export - most likely mondo problema. However I think you can add a fill within the gdl script. It should be very easy but need to know if you want dumb or smart!?
/Mats
AC 25 SWE Full
Mats_Knutsson wrote:
a cut fill?
Is this possible?
Hi Markus,
/Mats
Id u know how to do that with GDL, WRITE MAN !
a cut fill?
Is this possible?
Hi Markus,
/Mats
Hi Mats. What i am trying to do is (component -> gdl object)
The result after transferring the data by choosing surfaces, ended up with that the roof of my building consisted of both roof elements and wall elements.
A another problem is how this option selects all vertical surfaces on fx, a wall element, then converts each of the faces in to a archicad wall element. The result here is that your original sketchup element is now consisting of four wall elements one for each face. This is a problem.
Smart export??
