‎2017-08-17 07:00 AM
‎2017-08-17 10:43 AM
‎2017-08-17 11:12 AM
‎2017-08-18 02:44 AM
‎2017-08-18 02:50 AM
‎2022-05-15 04:12 PM
Why is this very needed feature still in legacy in Archicad 25 and only for single plane roofs? What if my project is still in development? Are there any plans to implement this feature or do we have a place to vote for it?
‎2022-05-16 03:23 AM
It is not a feature that is 'still' in legacy option.
It is a feature that was moved to legacy option back in version 16 when we got multi-plane roofs.
Multi-plane roof display differently to single plane roofs and therefore handle skylights differently.
I don't know if that is good or bad - I don't use a lot of skylights and I only use multi-plane roofs for the most basic of roofs (never when roofs of different levels overlap).
So we can work the 'new' way, and if you can't achieve what we did before, you can convert to single roof planes and switch to legacy mode.
But if you can't do what you want with the 'new' proper settings, then report it to your local Archicad support and see what they say.
Maybe something needs to be changed.
