Slab Accessories
Finally found a solution to my associative labels by using the slab accessories tool which works fine
Give that the slab accessories tool is able to read the coordinates of a slab in plan to define its own line am i able to draw out of the slab other information such as its thickness
i am tying to establish the base height of a slab
4 Replies 4
Have You found any documentation on the Accesories? (Particularyly - the slab accesories?) I am trying to work on one idea - but the lack of documentation makes me little mad šŸ˜‰
Best Regards,
Piotr
sorry don't have anything at all other than that provided by GS on web
LiHigh
IMHO,associative label created as Label subtype is stiil best approach.
Howard Phua
Win 10, Archicad 19 INT
you are right however i wanted to show storey sensetivity which i was unable to do in R9, R10 no worries
slab accessories was my only option
