Learn more
Slide window with different sashes
Hi! how do you make different sash size in a slide window?
Thanks
3 Replies 3
That all depends on if your object is capable of doing that - i.e. the option has been scripted in.
If not you will need to make a custom window object from slabs - but it will not be adjustable.
thanks, i thought there was some kind of trick using different type of slide window and can be manipulate.
thanks
I don't think the Graphisoft windows are adjustable (I don't really know as I don't use them) but maybe something like CADimage or 4Dlibrary windows are (again I don't use them so can't say for sure).
I have my own custom made windows and yes they are adjustable - but I can't share them sorry.
It is possible but you might have to hunt around for the right objects and be prepared to possibly shell out a few $.
