Sliding window with fixed transom?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2012-11-11
08:48 AM
‎2023-05-26
11:18 AM
Rubia Torres
‎2012-11-11
08:48 AM
1- Apply fixed window but separate the panels ( the problem with this is that it won't show correctly in plans as it won't be sliding)
2- Apply sliding window and add a frame to show the upper part as a sash ( the problem with that is that in elevation there will be double frame in the middle all the way through the transom).
Any ideas?
EDIT:I found a sliding door with transom, but it comes with sidelight and I just can't turn it off? D Sliding 1Sidelight Raised 15 and D Sliding 2Sidelight Raised 15. any way I can turn the side lights off?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-11-11 09:46 AM
‎2012-11-11
09:46 AM
Two things you can do is either use the Modular Joinery Object or in your #2 problem, you could SEO one of the frames so there isn't two frames in elevation.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-11-11 11:02 AM
‎2012-11-11
11:02 AM
I don't think that SEO would work. it will be a headache in the elevations, and it won't be correct in schedule.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-11-11 01:49 PM
‎2012-11-11
01:49 PM
zeropointreference wrote:SEO does not work with windows or doors.
...or in your #2 problem, you could SEO one of the frames so there isn't two frames in elevation.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
