Slopes with array
Hello everybody.
I draw roofing systems for flat roofs where we use insulation to build slopes.
Today, thank you for making the top layer it works ok. To create slanting plates, we use the wall tool with a profile. Profile has slope 1:40, 1:60 and 1: 100.
1:40 has 2 plates and 1:60 has 3 plates while 1: 100 has 6 plates.
The structure below uses the Slab tool.
See attached PDF file.
Using this method cumbersome so I thought I would create an object that we can only pull out with hotspots.
What I have made is the profile of the slant to call it in 3D, then I thought I could use the array to extend it from plate 1 and then plate 2 and on plate 3, plate 1 will reappear after plate 2. It fades almost correctly but from plate 2 it comes to plate 1 and flat 2 at once.
What I want is that I can stretch out to get one and one.
Then the question is what I'm doing wrong.
All help is of interest.
11 REPLIES 11
sinceV6 Thousands of thanks
That you spend your time doing this to me.
Now it's akurate the way I wanted it to work prefet now.
I've only tested it where I have two sizes on the plates that are 1:40 and 1:60. slop.
But I think you will also work at 1: 100 that I have up to six disc sizes.
So thanks again and to Ling who contributed here
Laurits
sinceV6
Glad I could help.
Best regards.
