Snap on rafters;
I am working on roof plan, i created rafters with roof wizard and after placing rafters when i try to annotate them it doesnt snap on rafter (snap is turned on and it works fine on everythig else).
Is there some option that i need to turn on or it snap isnt possible for rafters?
Thank you in advance.
Also, it can snap on rafters axis but not on their outline.
The rafters place by the wizard are just objects.
These objects are not scripted with snap-able hotlines on the edges (only the axis) and only have hotspots (nodes) in certain locations.
So you can only snap to those nodes and axis - just like any other object can only be snapped to at certain locations.
