2019-04-15
10:22 AM
2023-05-24
09:55 AM
Rubia Torres
2019-04-15 11:02 AM
2019-04-15 01:33 PM
sboydturner wrote:I've got too many objects.
Mats,
To get these objects to schedule to the correct zone add a 3D hotspot offset from the object on the side on which you want it to be scheduled, you can do this with a stretchable hotspot
Scott
2019-04-15 04:58 PM
2019-04-16 11:14 AM
Erwin wrote:Nope. Don't want any recesses
You can add Wall Recesses to zones, does that work?
Project Preferences > Zones
This does change the m² (obviously), then again there is floor finish where the door touches the floor logically.
Remember to update zones after changing this.
Maybe save project first, in case weird things happen!
2019-04-16 12:40 PM
Mats_Knutsson wrote:How many different objects would you have that are accessories to doors? I am assuming you are using scripted parametric objects that are used from project to project, where adding a single line of code to each 3D script would take about 1-2 min per object once would save many times that in future projects
Even Pyrrhus wouldn't do that.
2019-04-16 03:15 PM
