Stairs, stairs, stairs...
Hi, I'm still quite new with ArchiCAD and I have a lot of issues in convincing the program to represent any flight of stairs I create the way I want it.
In particular, I don't understand to which story should a flight of stairs belong to in order for ArchiCAD to be best pleased? I mean, I love the software, I'm very happy with almost everything else, but when it comes to stairs... I always end up with dashed lines (invisible structure) were I really wanted it to be solid, step numbering that is set to be visible but it isn't, flights of stairs that disappear altogether... It's really quite entertaining, but you know, time consuming!
Long story short, my two biggest issues are:
- with exactly the same representation settings, a normal rectangular one-flight stair is shown as 'invisible structure' while a complex-geometry one (the one you create with a hatch and a line) is shown as 'visible structure' (the one I wanted!);
- step numbering: I need them to show in the relative floor plane, while they only show up in the floor plane above it...
Is it only me doing it wrong? I've spent a long time trying to figure this out, but I'm still lost. Any suggestions?
Thanks!
Enrico
Thanks
Enrico
4 REPLIES 4
You can fight with the built-in stairs and StairMaker, or you can look to add-ons such as Cigraph's excellent ArchiStair 2.0 ...
AC 28 USA and earlier   •   macOS Sequoia 15.3.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Enrico
You might want to consider Steve's suggestions in this thread.
http://archicad-talk.graphisoft.com/viewtopic.php?p=149824&highlight=stairs#149824
It's the only way to get structural details out that make sense for the specific stair your building.
I'm sure others can help out with the how to show by story if your going to go that generic route, but white or other appropriate fills can end the headache real quick on simple residence stars.
lec
Erika Epstein
Enrico
1.For the first, check the 2D symbol type. It sounds like you have it set to type 13 which over-rides the line type to show all lines dashed.
2. On the Parameters tab >2D Above Home Story
Uncheck "Show Numbering"
3.Assign the Home story for the stair. Consistency is the key. I typically assign the home story of the stair to the one from which it goes up to the next story. Then you choose on which stories it will show.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
From demonstrations I have seen, Cadimage's Stair Builder for AC12 looks good, very versatile, and displays well in plan views.
