Standard Library Objects Not showing properly
Running AC22 Solo, i've ran the updates last week after not using for a while, and now all my standard library objects are playing up.
This is particularly noticeable on Windows and Door Objects, only the default objects are showing So if i choose a Basic Door and then try to adjust the style to suite what i need i am still only showing the same general door panel.
Its not affecting the ability to alter sizes, or replace with an alternative object, change materials etc. but i cant adjust styles.
Can anyone suggest how i can resolve this issue, or am i going to need to uninstall and reinstall everything.
1 REPLY 1
David Maudlin
PaulPearsonJSY:
Two places to check:
1. Door Settings > Door Settings > Door Settings & Attributes > Model Attributes > 3D Detail Level, if this is set to "by MVO" then:
2. Model View Options > Detail Level of Doors, Window and Skylight Symbols > 3D and Section/Elevation > set this to "Full".
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
