Tracey Sharples
Glass balustrade with glass door
Is it possible to create a glass balustrade that has a door set in it, such as for a pool fence?
Thanks
Archicad 26 Win11
6 Replies 6
Assuming you are using the new railing tool in 21/22 then not easily with one railing.
Break it up so the gate is a separate piece of railing.
Then add your own hinges and catch if need be.
You can even rotate this panel to appear open.
Add an arc for the 2D door swing.
This is easier than trying to manipulate one panel to be the width of the gate and then turning internal and end posts on/off and adjusting their offsets.
Don't try and use the bracket fixing for the hinges as you can't turn them off on one side only.
Tracey Sharples
Thanks for that, Barry. Where did you get the hinges from?
Archicad 26 Win11
I didn't - I just drew them on the screen shot.
But just use a small wall or slab or morph for them.
Tracey Sharples
Thanks again! Wouldn't a pool fence with gate be a wonderful addition to archicad!
Archicad 26 Win11
jakubc7
Hi Tracey. I have come across the same issue while trying to work with the Railing Tool. Since I draw the pool fence quite a lot I thought I might as well create my own object. Works well for some types of shower screens too.
It's been sitting in my library for a while but your post triggered me to release it. You can download it at my website and it should soon be available on BIMcomponents.
Hope you enjoy it. Let me know if you encounter any bugs. Happy holidays!
http://www.jcdrafting.com.au/gdl-objects/20181222/frameless-glass-balustrade-and-screen-22/
ArchiCAD 10 - 29 | Windows 11
Lucid Design Studio | Perth, Western Australia
Tracey Sharples
Thank you so much! Will have a look after the chrissy festivities die down.
Archicad 26 Win11
