JGoode
Status code help?
The object in the picture is almost exactly how I want it. It shows the lines in elevations that I want it to show except one. For the rest of the lines I changed the status code to 10 which changes both sides of the elevation on all apart from the one that is missing. I can't seem to work out why this has happened? Why would this work with all of the others and not this one? I have tried changing lines of code above and below to display a line but no luck :S
Thanks
ArchiCAD 27
Windows 10
2 Replies 2
Hard to say what is happening without seeing the code for that element.
That's it!
Why do you, JGoode always attach pictures, and not a code snippet - (but better all the code)- is completely unclear.
