Shura228
Steel Frame isn't loading fully in 3D
For some reason steel frame isn't loading fully in 3D
Are they cut by any other element or is there a Solid Element Operation performed on them?
If you select a singe element, do you the little rectangular SEO Handle that indicates there are SEOs performed on the element?
runxel
Looks like you have a 3D cut active.
