I'm using AC10. My libraries are located in the server. When I try to place an object from AC 10 Library/Object Library/01 General/Detailer Library 10/Steel Shapes 10, I get this warning message: Unknown extension at line 22 in the 2D script of file DET_HP>Shape10.gsm. I was able to use that library before with out any problem. I did not modify any of the object located on that folder. I can not place any of the object under Steel Shapes 10. I appreciate your immediate help. [/img]
hey!!
this is the message i get when i modify an object and i do it wrong
i mean that you modify a parameter maybe too much!
like for example in a window you make the transom bigger that the actual window
i hope i could help
Line 22 of the 2D Script for this object is:
ch1=open("data","DET_Steel_10.txt","separator='\t',mode=ro, Library")
so it appears that the problem is with .txt portion of the code. Either this object or the called file is corrupt or missing, so you may want to try replacing the library from the installation disk.
