2004-05-24 03:49 PM
2004-05-24 04:09 PM
tprokop wrote:A simple option would be using a parameter like len2, and define at the begining of the script that len2 = A.
Is there a way to make an object that can stretch in two directions from a common origin point? At a 90, the objects uses the A and B codes to stretch each leg, but we would like the objects to work with variable angles. Any help or suggestions would be appreciated.
IF GLOB_MODPAR_NAME='galq' THEN
IF galq=30 THEN
PARAMETERS A=22"
PARAMETERS ZZYZX=48"
ENDIF
IF galq=50 THEN....
In plain english, this give :
