griggadee
Stud Wall Object
Hi folks...
Does anyone have any good suggestions for creating a stud wall object like this one from Applecore Designs but for free:
http://www.youtube.com/watch?v=DcuIjDV8lM0
Ideally, I would create a composite wall with insulation and studs built-in, but this appears impossible in ArchiCAD right now.
Thanks,
Paul
Paul Griggs BSc (Hons) MCIAT MCIOB
Chartered Architectural Technologist
AC23, i5 3570K Processor, 16gb RAM, NVidia 570GTX Graphics Card, 250gb SSD Drive
11 Replies 11
Ernest Atanasiu
Don't know which version of AC you have, but there is something available for 16 on bimobject site from norgips http://norgips.bimobject.com/SE-C70-dB-2-2-M0
arch. ernest atanasiu
AC 10-29 INT/GER/FR on Win 10/ Win 11
griggadee
Thanks for the speedy reply. I am using AC15. Will this not work on there?
Paul
Ernest Atanasiu
it works. take a look here also: http://www.youtube.com/watch?v=Spjg36F1iyA
griggadee
You my friend are a frikkin genius! Thank you so much!
I will have a play right now and hopefully I can hit the jackpot!
One thing though, I don't think you can select timber studwork unfortunately, only metal profiles! That's a bit rubbish of them don't you think!
There is another forum that would definitely benefit from your suggestion and I will post it soon to update them, because this software allows you to create composite walls etc. with scaled and correctly placed batten insulation. That is something that many ArchiCAD users seem to find a nightmare!
Thanks again!
Paul
Ernest Atanasiu
well, I think norgips are dry-wall manufacturers, so wooden studwork...
glad I could help, what other forum are you talking about?
griggadee
Norgips are plasterboard manufacturers and supply a full range of plasterboards as well as complete drywall systems. As a vast amount of plasterboard stud walls feature timber studs, I would have thought they would acknowledge this and helpfully feature a timber stud option in their object but hey ho!
The other thread I was talking about was:
http://archicad-talk.graphisoft.com/viewtopic.php?t=19077&highlight=
Although, my intended comments appear to be way out of date as the answer can be found here:
http://dedicated-cad.ie/archicad/archicad_tip028.html
The thread had just not been updated!
or you can use the wall framing accessory from Design/Design Extras/Accessories/Wall Accessories/Wall Framing Tool
Best regards,
Ede
P.S. Don't forget to load Accessories Library too
Marky
http://www.youtube.com/watch?v=SmD9ivaWQCA.
You don't have to go to the Profile settings, just use the Insulation 01 in the composite wall dialog window and pick Fit to skin.
Works as it supposed to.
AC 6.5, 13 - 19 Pl, OctaneRender for ArchiCAD, MoI 3D, Blender; W7 Pro 64;
i7-4790K/32 GB; GTX 980/4 GB
I downloaded the Accessories for 16 but says it's missing from the loaded libraries even though it shows up in Library Manager.
And then there is the statement that I don't need to load it myself, but......
