Sunshade in incorrect position
Greetings,
I want to put a sunshade in my window with a specific size. I entered the size of my sunshade, therefore it levels from the bottom of the window to the top. I wanted it to be leveled from the top of the window to the bottom, but with that specific sunshade size.
Try creating a custom window with this technic.
Hope this helps.
Lingwisyer
Guru
There is no way to modify the reference point of the shutters... As a workaround, you could model a second thin wall in front with an empty opening and shutter at the height desired.
