ā2007-06-27
11:57 AM
ā2023-05-26
12:22 PM
Rubia Torres
ā2007-06-28 08:06 PM
Achille wrote:Like what kind of problems (usung the AC10 temp. in AC11)?
........In fact when starting from scratch the problems do disappear, but it is impossible for me to start from zero...
ā2007-06-28 08:09 PM
ā2007-06-29 06:36 PM
TomWaltz wrote:Just for clarification: if I choose to move away from Favorites and use the AECbytes Method as described, I will still need to "Re-vamp" the "visual favorites" also when upgrading.
You would be better off actually adjusting your favorites for the new library (which you would have to deal with on every single PLN brought forward) or consider switching to a visual favorite method like the one described here:http://www.aecbytes.com/tipsandtricks/2006/issue13-archicad.html
ā2007-06-29 09:34 PM
Jay wrote:You're right, you would have to.The difference is that you would get a little dot for each missing object which serves as a much easier cue for finding what's missing.TomWaltz wrote:Just for clarification: if I choose to move away from Favorites and use the AECbytes Method as described, I will still need to "Re-vamp" the "visual favorites" also when upgrading.
Previously (AC9 to AC10) I was told that the AC9SE library parts parameters could transition to AC10 Library with just the Alt-click, Ctrl-click method. Alas I never could get the AC9SE library to work for me. I have re-saved my Favorites now based on the AC10. Can the AC10 Object transfer over to the AC11 Objects with the Alt-click, Ctrl-click?
ā2007-06-29 09:50 PM
TomWaltz wrote:The Dot at
TomWaltz wrote:This is always the Upgrade Question, What MIGHT we have to re-tool for.
You MIGHT be able to inject to a new object. If the new object is seriously different with all different parameters, you might not.
