Text Justification
I'm trying to have some multi-lined text be able to be justified (within the block - if that makes any sense), and I can't find the setting. If I use the anchor option from
DEFINE STYLE name font_family, size, anchor, face_code
I just get the... anchor that changes (self explanatory, I guess). But while the anchor may move to the center, the text is still left-justified. How could I get it to justify to the center, or right for that matter.
2 Replies 2
Frank Beister
Using TEXT2-command will need manual justification by using STW(). As normal Text has an Anchor AND justification line.
Better use RICHTEXT, TEXTBLOCK AND PARAGRAPH for that. Have a look to the manual. It will provide you full rich text format.
Sorry for the late reply, but this looks interesting/promising. I'll need to look into it - haven't used these commands yet. Thanks for the info.
