Learn more
The Best API
I have found the best api for ArchiCAD is by far Archiforma. Does anyone agree?
7 Replies 7
I like ArchiForma quite a bit, but in my book ArchiTerra is the best API. Cigraph is doing a great job.
API?
What means for API? It should be Application Programming Interface. The Archicad API is made by Graphisoft, not any third partner.
So, I think you should say "Plug-ins", or "Add-ons".
Quite so.
fuzzytnth3
I use ArchiDesigner and have found it straight forward and simple to use for all my difficult shaped windows.
The version I have is for AC 7.0 so I'm not sure if there are any improvements for AC8.0 my only gripe with the version I have is that it doesn't do corner windows other than that it works just the way I want.
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
Ben Odonnell
Terra and ArchiLumos
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Ben Odonnell
You should have made it a poll. Would be interesting to know what people are using in ArchiCAD.
Ben O'Donnell
fuzzytnth3
Ben
I would be interested to know how does Archilumos preform (render times wise) compared to other radiosity renderer's such as Cinema 4d or Strata 3d Pro?
