Tips on animating objects
I just saw a discussion on linkedin about how to animate objects in ArchiCAD. This is actually surprisingly easy to achieve with basically any existing parameter - a fact most user don't realize.
Eg say you have a car object that you want to move 1m metre per animation frame, all you have to do is add the following line to the top of the object's 3D script:
ADDx GLOB_FRAME_NR * 1 !1 moves it 1m per frame.
Anyone got any other tips
6 Replies 6
Can you make the wheels spin?
haha sure can! just multiply their angle parameter e.g. wheelAngle like this:
wheelAngle * (GLOB_FRAME_NR * 15) this will move them 15 degrees per frame.
Now if you were really clever you could use a calc to work out how much your wheels should turn, based on how fast the car is moving each frame 😉
And if you get the calcs wrong and the wheels spin too fast you'll get plumes of smoke and black lines all over your plan.
rocorona
We had a discussion on this (animate objects) a few weeks ago, on ArchiRADAR, started on an old tutorial.
The aim, in this case, was to simulate the swing movement of a boat, while moving ahead.
The solution proposed is enough for a simple animation, although the waving movement is a crude zig-zag, not something smooth like sinusoid.
The whole thing is in Italian, but you can find something interesting.
Log-in to the forum, to see images and to download the "swing-all-objects" object (oscillatore2.gsm)
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
Very interesting...
Sounds good. We got a smoother motion on a couple objects by multiplying the frame number * SIN or COS
