‎2020-02-07 02:54 AM
‎2020-04-17 08:47 AM
mnguyen wrote:Coming back to the original topic. What is the AddPars folder useful for? I tried importing one surface from the AddPars folder but AC didn't do anything. The sum of sizes of the individual surface files under the AddPars is far greater than the size of "main" xml.
Best regards,
Minh
‎2020-04-20 10:51 AM
Mats_Knutsson wrote:Hi,
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2020-04-21 01:50 PM
I hope you are doing well during these trying times!
Thank you for your question!
When you export the attributes, you'll get an XML file, and a folder next to it (the default name of this folder is AddPars in the INT version), that contains the XMLs of the sub-attributes.
The main XML file contains all of the main attributes, and it links to the sub-attributes relating to the main attributes in the main XML. This link is saved in the code. Since you may have many sub-attributes exported to AddPars but only one main XML, the AddPars folder can be way larger than the main XML.
AddPars also contains XMLs for the Library Parts that are used by the saved Favorites, so they are/can be created for Favorites of Zones, CW, Stairs, Railings and for Materials/Surfaces.
You won't be able to import the XMLs from AddPars folder to ARCHICAD directly, because it lacks certain value. My suggestion is to import the main XML, then import any sub-attribute that you need from there.
I hope this will answer your question. Let me know if you need any further help!
Thank you very much!
Best regards,
Minh
‎2020-09-30 07:25 PM
‎2020-10-01 09:44 AM
bouhmidage wrote:Hello,
Hi !
when copying my archicad template folder, wich contains the AddPars folder, all XML, copy process becomes veeeeery slow when it comes to addpars folder
is there a solution ?
Minh Nguyen
GRAPHISOFT
‎2020-10-01 10:31 AM
‎2020-10-01 10:46 AM
bouhmidage wrote:Hi,
Thank you for the quick reply !
the problem is not with ArchiCAD
the problem is with the created Addpars Folder, when i copy it into a flashdisk, or an external HDD drive to move it to another machine, the copy process of the folder content becomes very slow,
Minh Nguyen
GRAPHISOFT
‎2020-10-01 11:06 AM
‎2020-10-01 11:17 AM
Minh Nguyen
GRAPHISOFT
