‎2010-02-15 05:04 PM
‎2010-02-15 07:56 PM
‎2010-02-15 08:28 PM
‎2010-02-15 09:29 PM
‎2010-02-16 12:48 AM
‎2010-02-16 03:30 AM
‎2010-02-16 03:36 AM
GSNA wrote:In such a case, SEO (solid element operations) would also work.
Also, I am not really concerned about the floor plan but rather the 3D appearance.
‎2010-02-16 07:00 PM
‎2010-02-17 03:26 AM
GSNA wrote:Unfortunately, the variable wall thickness routine is not perfected as you have seen. When I wrote the object, I needed a niche that bumped out the back side of the wall and took on the wall properties. I might get some time this weekend to look at it and but I can't promise anything (I will post it if I am able to get it fixed up).
Your object will be displayed 100% accurate on the front by selecting the "Use Wall Thickness" ON but it will bump out on the other side. If am changing to OFF and change the value to 2" wall thickness the header is hovering above the sides![]()
Otherwise its perfect. Any ideas?
‎2010-02-19 12:32 AM
