Trench Drain for ArchiCAD
Hello!
I need a drain for my project...
Carrington's one for Revit is perfect! Is it available for ArchiCAD?
If not, what ArchiCAD object could I use that can be similar? I haven't found any...
Thank you!!!
4 REPLIES 4
Create a profile in the Profile Editor for the body and use either the beam or wall tool to extrude. Multiply small beams for the grate. Etc.
I´m using objects from ACO library (it´s in hungarian langueage). Download it from here.......http://www.mediafire.com/?gszra2kvvml0zzk
Ohh myy these are perfect!!! Thank youu!!
I don't know hungarian, I'll manage with Google translator and checking the catalog in the site acousa.com.
Cheers!
I always use a custom profile (as Karl recommended), but I just leave the grate solid too, then assign a material with a slotted texture map. (fewer polygons that way too)
