Triangular Gable Vent with legs
archislave
I can't understand why GS does not have a triangular gable vent when it is one of the most common elements in US residential architecture. There are arched ones and i figured out to reduce the curve resolution to 3 or 4, but you and adjust the angle to match the roof.
Why did they not include this?????? Absolutely Rediculous!!!!!!!!!!!!!!!!!!!!!!!!!
Help!
Archislave
archicad 26.0 US, M2 Macbook Air
2 REPLIES 2
archislave,
You will probably have to build it in the plan using slabs and roofs
and save it as an object or a window.
Peter Devlin
I'd suggest using a triangular window (e.g. W Triangle Fix 10) with some wide (2") horizontal muntins. Shape it in a 3D window.
Richard
AC26 (since AC6.0), Win10
