Haneef Tayob
Truss object with overhang
Hello
Anyone know where I can find a good truss object which allows me to set overhangs:
I want to try to avoid using trussmaker or creating a new object as I find these to be relatively slow, especially when you're making lots of changes and trying different options.
In early stage of the sketch design, when thing are still going through lots of changes, I usually use the standard AC9 Pitched Howe Truss which is fully parametric. I then add the overhang with a separate rafter object using roof wizard as the 'Pitched Howe Truss' object does not allow one to set overhangs.
thanks
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
10 Replies 10
TomWaltz
Does the Truss Set on Objects Online do that?
If not, maybe I should write one that does and add it on there...
(maybe with graphic hotspots for variable slope and overhang size....)
Tom Waltz
I always use the TrussPro object. There are no Webs. Once I created Webs with Rafters for 3D Representation, but mostly the Webs are added as 2D Polylines, grouped and then copied into Crossections that require them.
TomWaltz
That's almost exactly what I was imagining, but I can't help feel like the overhangs and slope should have hotspots to control them.
"Hi, My name is Tom, and I'm a Graphic Hotspot addict."
Tom Waltz
Well Tom, if you create a Truss Object make sure that the Height at Heel Parameter works correctly. If you say want an Extra 1/4" or 2" (for a 8" or so total Heel Height) added to the Heel Height of the TrussPro Object and it does not display properly in 3D especially with the OpenGL Engine.
An example: for a 7 1/2" Top Chord (6:12), 5.5" Bottom Chord (3:12), any Heigh Height under 0'-11 3/16" displays erratically.
TomWaltz
Jay
by "Does not display right", do you mean that it overlaps itself and seems to turn inside out? Or is there another problem I'm not seeing? Or that there are still extra lines when you set the clip plane?
(man, those seem like obvious problems!!)
-Tom
Tom Waltz
OpenGL Shading is Missing It looks like the front and back faces of the truss are Blank when "turning" the 3D Window.
TomWaltz
If I EVER write an object that does that, I hope the client will smack the crap out of me for it.
Tom Waltz
Haneef Tayob
Thansk fo rall the helpfull feedback. Unless I'm mistaken, it seems that AC9 international version does not come with the TrussPro object.
In the meantime I'll have a look at ObjectsOnline to see what they have to offer.
Haneef Tayob
David Maudlin
Tom:
Jay's problem was discussed here: TrussPro Object view Problem
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
