‎2006-02-03 10:06 PM
‎2006-02-04 02:26 PM
Jay wrote:
Using the TrussPro Object with a Scissor Chord the 3D view has a "full-panel" when viewing it it on direction. it is okay viewing it in the other direction.
‎2006-02-04 04:25 PM
‎2006-02-04 04:28 PM
‎2006-02-04 07:29 PM
Jay wrote:Jay:
Only selecting one Truss and viewing with the Open GL Engine results are a little better. The truss is not partially wireframe and the Scissor can be seen regardless of direct of view. there is no shading though?
Can any one else confirm this?
‎2006-02-05 02:29 AM
‎2006-02-05 03:03 AM
‎2006-02-05 03:20 PM
Jay wrote:
The Trusses have a 8 41/64" Heel Height because that is the True height of trusses that are manufactured (given a 2x8 top chord which is 1/4" raise off the bearing).
If the Truss Heel height is set to zero the problem does not occur. I guess I will just have to add the raised top chord dimension (1/4") to the over all top chord dimension. Which means adding 0.289425" to the depth of a top chord that has a 7:12 pitch.
