UI_PICT -HELP
Cosminn
Hello everyone, i have a problem creating UI_PICT. All my pictures (jpg or png) are so unclear. I created the png. file directly from ArchiCad, missing something when creating the png. file?. I will attach something to be easy to understand.
Sincerely,
Daniel
1 REPLY 1
Jochen Suehlo
Do you use the same size in the UI_PICT-Command as the picture has?
If not, that could be the problem.
Another possibility is, that ArchiCAD does not save a clear picture.
In that case make a screeshot in the disired zoom size; for me this is a good solution.
Jochen Suehlo . AC12-27 . MAC OSX 14.4 . WIN11
GDL object creation: b-prisma.de
