We value your input!
US Library Garage door leaf problem...
I have latest US library......I just noticed that for some reason I cant get this particular door leaf to show the glazing. It's all one common material. I tried every setting possible to make the glazing show.
Ideas?
The settings
Erich
Not that this solves your problem, but I don;t think that the leaf style you are using has a glass surface defined. If you try switching to a different panel, such as style 5 in the same door, the glass appears.
I am sure someone more versed in AC than myself can direct you to a solution.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
